Super Beginner question, how to approach the design.
gbkwiatt
Message 1 of 52
gbkwiatt
So I am trying to create drone model for myself, I am inspired by one I found somewhere online.
At first I thought it will be all simple because it's all symmetrical, but now I am stuck on extruding model from sketch.
So this is what I got
And this is where I want to go:
What would be the best approach? Of course I know nothing about blending parts together yet so it's hard for me to understand, but I bet there is some easy approach to that.
I was thinking wouldn't be better to have another rectangle on top and somehow blend it together with those curves.
How would you approach that ?
Replies (51)
Message 41 of 52
gbkwiatt
This.. is awesome, I just watched it all, and now I am going to watch it again while doing same along the video.  Very informative, and all this little tricks. It's great.
Is there any way to download that screencast, so I can save it so it won't get lost ?
Message 42 of 52
gbkwiatt
I am about to finish with my model (initial shape). all was going fine to that point including mirror duplicate.
On last step when I do mirror duplicate, box view looks okay
But smooth mode does that
Why is that ?
I can see it creates gap between them but why ?
ok I think ?I fixed it by manually welding points
Well, no I didn't fix it, when I do last mirror, parts overlapping and not creating one model
Message 43 of 52
gbkwiatt
Well it was something to do with legs not being symmetric, but it's all good now
I've added a bit of asymmetry on top, and bulked it on bottom and that's what I wanted
Message 44 of 52
TrippyLighting
You are free to accept my last post with the screencast as the solution 😉
Message 45 of 52
gbkwiatt
Forgive me, but I have side question.
I am trying to make some nice connection for the legs, so they can be attached separately. My current drone has something like that which is pretty simple and works.
Just push and it works.
Trying to to same thing on current model, I started adding shape  to the bottom of the leg.
But I won't be able to close it.
How should I approach that ?
Message 46 of 52
TrippyLighting
Share the model so I can see the history and then I can show you.
Message 47 of 52
gbkwiatt
I actually changed approach. I think it's better to create leg first, and they cut it out with that shape. At least that's the idea, don't know how to do it yet. I am attaching my project
Message 48 of 52
gbkwiatt
Aaand another question ( I promise it's a last one). How do I make some kind of groove, or or a line guide for cutting the lead off the top ?
I can't add points in T-spline, because that messes up the shape.
after 3D printing the body I need to cut the lid out -around 3-4mm for the carbon fibre wrap, is there a way to add lines and extrude them without changing the shape of the model ?
Message 49 of 52
davebYYPCU
Make a top view sketch, use it to Split top Face,
Use Pipe > Cut for a small groove on the face edge.
Might help....
Message 50 of 52
gbkwiatt
Awesome, simple as that
I will be an expert by the end of the month
Message 51 of 52
gbkwiatt
ok I promised it will be last question but I have another one, Why when I am on T-splin form mode when I have lines like this
after clicking finish form it changes completely
is that something to do with history mode ?
Message 52 of 52
gbkwiatt
now  I think I have everything I need. Once again than you everyone for help.
