Subtracting one object from another changes surfaces to opaque?
I wanted to subtract one transparent object from another. I need them transparent so I know what's going on inside. When I selected the "tool" object, the object became opaque and finalising the operation resulted in an opaque area in my cylinder. I was expecting a hollow spot which is what 123D Design does.
Screenshots:
Oi90MB0
rOmSD2u
bYbQbKE
Sqe8I9F
kate.raskauskas
Hi @Anonymous,
What materials are your bodies set to? That opaqueness can happen with materials like steel or matte plastic because Fusion shows a new surface with the material's default appearance. If your materials are opaque, try changing them to a translucent one and see if that fixes this issue. If your materials are already transparent, please upload your file and I'll take a look at it. 🙂
Best,
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
michallach81
The only way it could occur is if you've applied transparent appearance, not to the whole body, but face by face. If so, then your tube is metal except for faces you've specified as transparent. New faces that occurred are now metal. The only other way it could look like in your example is if that would be a bug. It may be confusing, so please watch this:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
kate.raskauskas
Hey @Anonymous,
Did these replies answer your question? If so, you can pick one as an accepted solution, which helps other users with the same problem find the information.
Best,
Kate Raskauskas
