Subassemblies reuse -> Falling Apart
mika.takalo
mika.takalo
When I'm reusing subassembly in an assembly, that reused sub-assembly parts are falling apart...exploding, why? Original sub-assembly is well jointed together all the parts and also made to rigid group, so it should not fall apart.
@mika.takalo
can you please share your file?
mika.takalo
No I do not share my files ever. I saved my work, shut down the computer and opened the same assembly very next day and it was ok. It is weird how these files are so vulnerable to this kind of bugs, which one can just disappear if just save and close the file.
@mika.takalo
try this: perform "compute all" in the subassemblies -> then open higher level assembly, update the linked components first and then also perform "compute all".
In addition, I also do a "compute all" (after doing some work in the file) before saving the file - just to be sure.
