Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
stuck trying to make a serrated locking plate pattern, any help is appreciated.
8 REPLIES 8
Message 1 of 9
jwhiteF8NZC
396 Views, 8 Replies
Hello i am trying to figure out how to create a serrated locking plate pattern to act as a slipping clutch, using body 28 and 27 in the attached model. i have very minimal experience and am self taught so please excuse my ignorance if this is simple and if you have to use crayons to get me to understand. a picture is added for example of the type of joint i am trying to build.
8 REPLIES 8
Message 2 of 9
laughingcreek
in reply to: jwhiteF8NZC
looks like a hirth joint-
Message 3 of 9
MichaelT_123
Hi Mr JWhiteF8NZC
Here is another method of creating a simple semi-parametric hirth surface
Regards
MichaelT
MichaelT
Tags (2)
Message 4 of 9
Warmingup1953
How will you produce this? Would an off-the-shelf item be suitable?
Message 5 of 9
jwhiteF8NZC
in reply to: laughingcreek
this is exactly what i am looking for, and now i know what it's actually called, thank you this help a lot.
Message 6 of 9
jwhiteF8NZC
in reply to: Warmingup1953
all items will be built by me in house on a mill so as im going im figuring out my limitations in the manufacturing side while i design, but i try to keep that in mind as i'm going along. so far everything is manufacturable with a lathe and mill, except maybe this part now might require a CNC setup unless as you said i can find it already produced which now that i know the proper terminology will be more fruitful but this is a one off piece for a vault door so not to worried about repeatability.
Message 7 of 9
jwhiteF8NZC
in reply to: MichaelT_123
thank you for the file and solution, i am surprised it was that easy, just shows how much i have to learn. maybe i pay for a class or two instead of asking such simple questions.
Message 8 of 9
Warmingup1953
I'm all for make it yourself but there I'd probably go shopping instead....... Good Luck!
Message 9 of 9
jwhiteF8NZC
thank you for showing me another thing i can use in the future, though the intention of this project is to learn by making something so no shortcuts for now until i have a better foundation of understanding of fusion and designing. but i do understand where you are coming from and i appreciate you trying to save me money and time.
Technology Administrators
