Hello i am trying to figure out how to create a serrated locking plate pattern to act as a slipping clutch, using body 28 and 27 in the attached model. i have very minimal experience and am self taught so please excuse my ignorance if this is simple and if you have to use crayons to get me to understand. a picture is added for example of the type of joint i am trying to build.
Solved by MichaelT_123. Go to Solution.
Solved by laughingcreek. Go to Solution.
this is exactly what i am looking for, and now i know what it's actually called, thank you this help a lot.
all items will be built by me in house on a mill so as im going im figuring out my limitations in the manufacturing side while i design, but i try to keep that in mind as i'm going along. so far everything is manufacturable with a lathe and mill, except maybe this part now might require a CNC setup unless as you said i can find it already produced which now that i know the proper terminology will be more fruitful but this is a one off piece for a vault door so not to worried about repeatability.
thank you for the file and solution, i am surprised it was that easy, just shows how much i have to learn. maybe i pay for a class or two instead of asking such simple questions.
I'm all for make it yourself but there I'd probably go shopping instead....... Good Luck!
thank you for showing me another thing i can use in the future, though the intention of this project is to learn by making something so no shortcuts for now until i have a better foundation of understanding of fusion and designing. but i do understand where you are coming from and i appreciate you trying to save me money and time.
