Stuck removing material.
lindsay.fowler
lindsay.fowler
Greetings All 🙂
I am stuck and need to be schooled on how to remove this bit of material.
I normally do everything starting from profiles, then pressing/pulling/extruding. My dilemma today is that the bit I wish to remove is not quite flat and therefore not a profile.
Is there a different tool the experts would recommend for removing this little bit of selected geometry below?
Thank you.
Material I wish to removeMaterial I wish to removeScreen Shot 2018-09-26 at 10.23.57 pm.png
sanket223.patil
Hello @lindsay.fowler
Can you explain more , What you exactly want to remove . You have selected only the face .
Sanket Patil
Mechanical Engineering
Expert Elite
melvinbrian3d
just select the face that you want to remove.. and Press the delete key on your keyboard.
MelvinBrian3D
lindsay.fowler
Sure @sanket223.patil I wanted to remove the selected part. Eventually I worked out a way to do it by making a new sketch on a plane, projecting the geometry into it, thus creating a flat profile, and then removing it with the same tool I always use: extrude. Here is the result I wanted. I just think my method is a bit cumbersome.Screen Shot 2018-09-27 at 2.28.22 pm.png
Thanks @melvinbrian3d, I already tried deleting faces several times, unsuccessfully (giving up when the last faces refused to delete). Thanks to your post, however, I persisted further and was able to use your much more elegant method. Thanks guys - I learnt a better and easier way!
