I want to loft between the base of Body 2 and the top of Body 1(3), using the guide rails around the edge to create a nice filleted blend. This normally works perfectly when Body 1 is a single surface, however in this case it is 3 tangent connected surfaces and it will not work at all. I'm stumped, could really use a workaround!
Solved by g-andresen. Go to Solution.
Gotcha. I had tried that, looks like I missed the Chain selection though! Thanks!
