Can Fusion splice a part to fit into a fixed stock size?
ManmadeMFG
ManmadeMFG
I have some long wooden beams that are to be made from stacked laminated plywood. My beam is roughly 17' long 10" deep and has big curves on the end to reach the ground. Is there any way to get fusion to figure out figure out the best way to splice them in to parts that can fit on a standard 48x96 stock?
wmhazzard
There is no way that I know of to automatically slice the beam so the parts fit on a 4' x 8' sheet. You will have to slice it manually yourself.
etfrench
Are you using a scarf or a butt joint?  How much overlap is required?
ETFrench
ManmadeMFG
They would just be a butt joint with an overlap of roughly 4"
