Strange error message
HughesTooling
Consultant Consultant
Message 1 of 11
HughesTooling
Recently I've started to get an error message if I leave an Untitled file unsaved for a while.
Mark Hughes
Owner, Hughes Tooling
Replies (10)
Message 2 of 11
innovatenate
Autodesk Support
Autodesk Support
The steps to reproduce this are to create a new design and then just let Fusion 360 sit idle for some time, is that right?
Do you have Automatic versions enabled in the Preferences of Fusion 360? What versioning time interval do you have set? I'm in the process of doing some testing right now.
I note there have been some enhancement made recently. You can now get to the recovery documents by selecting the recover documents command.
I'll let you know how the testing goes.
Nathan Chandler
Principal Specialist
Message 3 of 11
innovatenate
Autodesk Support
Autodesk Support
So far, I haven't had much luck. Could you share a screenshot of your preferences? Any other guidance you can provide would be really helpful!
Thanks in advance!
Nathan Chandler
Message 4 of 11
I've gotten this message too before. I'll keep an eye out under what conditions it tends to happen and report back.
N
Message 5 of 11
daniel_lyall
@innovatenate
this is how it happens for me and it has happened when I have been useing it. I have Automatic versions set to 20 mins, (or it will just crash like it just has I will do a bug report on this)
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 6 of 11
HughesTooling
Here's a screen grab. There were no file waiting to be recovered and I don't use Automatic versioning. I've only been seeing the error for the past 3/4 weeks and it's always with an untitled document left open.
Mark Hughes
Message 7 of 11
innovatenate
Autodesk Support
Autodesk Support
Okay, I finally got it! Thank everyone!
This is more of a save reminder. I'm not sure it's technically a bug... With that said, I'm happy to take your feedback to the development team. What do you think it should say?
Nathan Chandler
Message 8 of 11
daniel_lyall
i would not call it a save reminder i have auto save on i have had it minutes after a auto save or a save i have done
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 11
HughesTooling
It makes sense now you've explained it, Fusion is trying to save a recovery file for an unnamed document. Maybe the first part should say something like Fusion can't save recovery files for unnamed documents and the second part of the warning should say "To avoid data loss, we recommend you save Untitled now."
Mark Hughes
Message 10 of 11
HughesTooling
I thought this was only happening with unnamed documents but I just got the error on a file that has been saved and is at v7. Maybe you could give a warning the file has not been save for X number of minuets or something but I don't see why it's warning about a recovery file.
Mark Hughes
Message 11 of 11
HughesTooling
OK this is getting more and more irritating can we please have on option in preferences to turn this reminder off.
Mark Hughes
