Message 1 of 17
04:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I found a strange behaviour that i think might be a bug.
While I was designing this part i found out that:
- Two faces that should be perfectly parallel are not. (One of them, which should be collinear with another face, has instead an edge that should exist)
- While using the "Midplane" command on these two faces, the plane that is created is not in the middle.
I don't know if these two odd things are related or not. Any advice? Did i make some mistakes in modelling the part?
