.stp Export with low opacity
karim_x10ka
Observer Observer
Message 1 of 10
karim_x10ka
Observer
Observer
hey everyone,
i have a motor head, and i created 14 models to put them into the motor for tensile testing, i set the motor head to 10% opacity and exported all of models, but when i reopened it, it was back to 100%
normally i do it in FreeCAD because it allows you to export with low opacity, but this model is big and FreeCAD can’t handle it
is there anyway to do it in Fusion?
its a .stp file
  • Help
Replies (9)
Message 2 of 10
CGBenner
@karim_x10ka
Welcome to the community.  I've moved your post to the Design forum for better visibility.  Good luck!
Chris Benner
Message 3 of 10
JHRendon
You mean you set a percentage opacity to some parts in Fusion 360 and when you open it again the opacity has gone?
Message 4 of 10
CGBenner
@karim_x10ka Hello, do you still need help with this question?
Chris Benner
Message 5 of 10
karim_x10ka
Observer
Observer
hello
yes thats exactly what im looking for
i set the opacity to 10% for example and leave others to 100%, i export it as .stp file and after opening it with fusion or any other software the opacity returns to 100% on all parts
Message 6 of 10
karim_x10ka
Observer
Observer
yeah
i still need help with this
Message 7 of 10
laughingcreek
@CGBenner - maybe someone from the translation team could look at this.  I suspect transparency attribute isn't supported by fusion's stp import/export.
Message 8 of 10
CGBenner
@karim_x10ka @laughingcreek
I'm going to tag in @RajkumarIlanchelian who might know someone (or the answer itself), but I suspect that this may be the case in any software when exporting to .stp.  I seem to remember this being true in Inventor as well.  But, it has been a few years for me.  😁
Chris Benner
Message 9 of 10
JHRendon
Well maybe it is not possible because the appearances do not match with fusion 360 libraries.
But you can apply them in Fusion 360. you have two options:
Press "A" key on your keyboard and apply a transparent material or right-click to the component or body and look for opacity control and select the opacity you want.
Message 10 of 10
CGBenner
Chris Benner
