STL Import
STL Import
Message 1 of 23
STL Import
  I have a small problem.  When I import some STL the scale is not correct but I do not find a way to correct this scale.
  Somebody can help me?
Replies (22)
Message 2 of 23
Mike.Grau
Hi @Anonymous,
Welcome to the Forum. You can maybe try a work around to import your *.stl into Fusion?
To Do This, you can follow these steps:
  1. You can go into the SCULPT Environment, also called Direct Modeling Environment
  2. When you click at the Insert menu, you will find the option to insert a Mesh as *.stl or *.obj
  3. Once you have selected your file, Fusion will ask you in which Dimension's you want to import your file
Here is a link to a similar post which might help as well. I have created a screen shot which shows where you can find the insert option.
I hope this information helps to import your STL.
Message 3 of 23
@Mike.Grau Thanks! That helped me. However, I now have a suggestion. I created my model by using the "Import" feature from the Data Panel. This allows me to directly import a STL file as a new model. However, there is no opportunity during this process to define the scale factor. Also, I opened my STL file in a text editor and could clearly see that it specified millimeters as the units. However, F360 imported it as centimeters. This is perhaps a case where having more than one way to do the same thing isn't necessarily good. Perhaps removing the import option from the Data Panel is the best option since starting a new project and inserting an existing file seems a bit more intuitive for me. Regardless how you approach it, the scale should be able to be defined in both processes.
Thanks!
Ian
Message 4 of 23
Mike.Grau
Hi @Anonymous,
I´m glad that you were able to import your design. I agree with you, that would be really helpful to have a feature
which allows you to chose the units to mm, cm or m. Just in case you have not seen this post in the idea station
with the link here, I think this is what we are looking for. I have voted for it.
I would really like to have it in Fusion in the future.
Message 5 of 23
I've added my vote and some additional comments.
Thanks!
Ian
Message 6 of 23
Thanks for your help. I was in busines trip a lot of times theses last week a do not have found time to test your solution but now it is done. Your idea is exactely what I need and it works fine. Thanks
Message 7 of 23
Hello @Mike.Grau
      I'm also having this problem. I imported a stl file in inventor and no way a dji phantom drone leg is 8inches in diameter. I was wondering if there are other solutions without using fusion 360? I'm still on inventor 2015. Thank you!
Message 8 of 23
TheCADWhisperer
The Inventor forum is over here
http://forums.autodesk.com/t5/inventor-general-discussion/bd-p/78
I recommend that you simply attach your *.ipt file (and/or*.stl) over there and someone will show you how to fix it.
Message 9 of 23
Mike.Grau
Hi @Anonymous,
Welcome to the Forum. Could you may post this question in the Inventor Forum and send the link to me via private message?
I´ll get in touch with an Inventor specialist on our end and we´ll  take peek at it.
Message 10 of 23
Hey Mike,
how do i convert the stl file which i imported into fusion? they said they aborted the process as there are too many triangles
thanks
Sincerely Gabriel
Message 11 of 23
TheCADWhisperer
@Anonymous wrote:
Hey Mike,
thanks
Sincerely Gabriel
On something that simple - I would use Base Feature rather than t-Spline and then Insert.
And then I would probably only use for reference to model a Revolve rather than convert to a B-rep.
Attach your *.stl file here if you can't figure it out.
Message 12 of 23
[cid:373b4135-468d-4247-ab88-d9776c4dba8b]
i am trying to but it wont let me select ok, help please? thanks
Sincerely Gabriel
________________________________
Notice: This e-mail may contain confidential and/or privileged information. If you are not the intended recipient or have received this e-mail in error, please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
Singapore Institute of Technology, Co. Reg. No. 200917667D.
Message 13 of 23
TheCADWhisperer
You are trying to do what?  Attach the file here?
Are you on Windows or are you on Mac OS?
If Windows, right click on the stl file name and select Sent to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Message 14 of 23
i just want to convert my stl file to a file which i can edit on fusion, there is a screenshot of my problem, if i send you the stl file, it will work on your com, but not mine, please help?:)
SincerelyGabriel
Message 15 of 23
TheCADWhisperer
@Anonymous wrote:
... if i send you the stl file, it will work on your com, but not mine...
I don't understand why, if I can get it to work on my computer, I couldn't demonstrate how to get it to work on any computer?
Message 16 of 23
Here you go:) thanks:)
Sincerely Gabriel
Message 17 of 23
daniel_lyall
@Anonymous you for got to add the file,  when you won't some one's attention use @before there name like what I did with your's
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 18 of 23
I see no "sculpt" option. Is this a feature that has been eliminated?sculpt.JPG
Message 19 of 23
daniel_lyall
Daniel Lyall
The Big Boss
Mach3 User
Message 20 of 23
So according to note in above link sculpt does not import exact sizes?? how does one import a stl and maintain size and shape? What I don't understand is why import doesn't read the units information and import at the correct size? For a program used to design things it would seem size should take on more importance to the developers than appears to be the case.
