STL creation not working properly
I just wanted to share this, don't know if it's only me, but right now, "Create STL" is not working, not even with "3D Print", this is what I get and it didn't do that before.
It's happening with every single file I try to create an STL with, here's with one of the grip component from your utility knife design example:
Uhlhorn
The same here!
When I select the root and try to save it as STL with the structure „One file per body“ it fails.
Saving with the structure „One file“ it woks.
When I try to export a body as STL after using the structure setting „One file per body“ it fails.
When I try to export a body as STL after using the structure setting „One file“ it works.
I hope it helps.
Uhlhorn
Try to „save as STL“ from the root using the structure setting „One file“. After this You should be able to export bodies as STL.
jeff_strater
See this thread:  new-stl-mesh-level-preview-broken-i-only-see-red-lol.  The problem is just a graphics problem.  As far as we know, the exported STL is still fine.  We are working on delivering a fix
Jeff
Jeff Strater
Engineering Director
Uhlhorn
When You choose „Save as STL“ with the option „One file per body“ than STL export fails. Perhaps these are two different issues.
Thank you, Jeff, I read that thread later yesterday.
