Correct workflow for a library of components?
I know that I can bring a component into another design as a linked component, but the component I'm adding must be in the same project as the design I'm working on. Is there any way to link across projects?
I have a component called "LCD module" that I use in a bunch of different unrelated projects and I'd like to have one master version in a project called "Library" that everything else links to. As far as I can tell, what I have to do instead is copy the LCD module design into each project that needs it then link it into the product design from there, so now I have a bunch of different copies of the LCD module running around and if I tweak something to improve it in one project, no other project gets the benefit of that new version.
Is there a better way to maintain a library of commonly-used components, or is Fusion 360 just a little weak in this area?
