Need help to get fusion work after this last update
h.touzot
h.touzot
I really enjoy fusion everyday for my work and hobby but since the last update today i think i will be mad.
Fusion is really unstable, crash for nothing like trying to make a draw of a simple part or going back in history could take 10 min where before it tooks less than one. Worse, i was unable to save my works cause it crashed before ending process.
Please how do i can go back to the previous version ??? i really need fusion tomorrow for my job.
Best regards,
Hugues
daniel_lyall
@h.touzot
if you have Sketch color sketch geometry based on constraint status under preview turned on turn it off
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
innovatenate
Autodesk Support
Autodesk Support
Looking through your error reports it seems that you are crashing when creating a 2D drawing. Does that sound right or are your crashing during other times?
Could you try using the reset to default layout command and see if it helps?
Could you try setting the Graphics Driver in the preferences to Direct X 9  or Direct X 11 instead of Auto-detect to see if that makes a difference?
One more suggestion, if you open an existing drawing before trying to create a new drawing, does this help?
Nathan Chandler
Principal Specialist
daniel_lyall
@innovatenate what I posted is a big problem as well it could be that, frank cao looked into it and had a different problem to what I had on the same file
Daniel Lyall
The Big Boss
Mach3 User
h.touzot
I don't know which proposition works, but i'm able to work this fusion, opening and creating draw !
Thanks !
