Stitch problem
Stitch problem
HughesTooling
Consultant Consultant
Stitch problem
HughesTooling
Stitch was improved in the last update but it now defaults to a 1.0mm tolerance, this is way to high for anything I work on. Is there a setting to change it to 0.01mm, sooner or later I'll forget to change the setting and a 1.0mm tolerance could cause problems.
Mark
Mark Hughes
Owner, Hughes Tooling
masa.minohara
Hi Mark,
Thank you for posting! I tried to find a way to change the default value but couldn't find one. I'll check with my colleagues and update you as soon as I can.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
masa.minohara
Hi Mark,
I have talked with the development team and found out that it's not possible to change the default value for tolerance in Stitch command, and for now we need to manually change it each time.
I have logged this as an enhancement idea (FUS-28108) with the development, and they will review this.
Thank you for pointing this out!
Masanobu Minohara
HughesTooling
Hi Masanobu
It would probably be best if it was set base on the General tolerance setting, so a tolerance setting of 0.12 would set the stitch tolerance to 0.01mm and general tolerance of 0.123 would be 0.001mm etc. I'd rather the stitch fail because the tolerance is too tight than forget to set it and have it use 1.0mmm.
Mark
Mark Hughes
