STEP/IGS upload fails
patmat2350
Message 1 of 9
patmat2350
For the past few days, every time I try to upload a STEP or IGES file, it hangs and fails. Never had issues before.
Oddly, when I use the process to directly upload an item from McMaster, it works. Sadly, McMaster doesn't have what I need.
Is this something new?
Edit: I uploaded the same file to Autodesk's viewer, it displays there just fine, so it's not a corrupt file.
EDIT #2:
The AD viewer has a function to "open in Fusion 360". Pushed the button, and it worked!
Still, why do I have to use a work-around? Why doesn't this just work in F360????
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@patmat2350 Can you confirm if you are on version 2.0.17457? We recently fixed a very similar issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
patmat2350
Fusion 360 2.0.15509 x86_64 /personal
Shouldn't I automatically receive the latest updates?
Message 4 of 9
RajkumarIlanchelian
@patmat2350 @You absolutely should. Not sure what happened. Can you manually update to the latest and this problem should go away.
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
patmat2350
Ummm...
No available update shows in jobStatus.
Tried the installer, get this:
Checked my version again, got this:
Suggestions?
Message 6 of 9
RajkumarIlanchelian
@patmat2350 Lets do this:
1. Close Fusion
2. Delete the shortcut that you are using to launch Fusion (this is important )
3. Go to add/remove programs
4. Select Fusion
5. Select modify
This will launch the Fusion service utility
6. Run the repair Fusion
This should create a new shortcut and take you to the latest version. You should now also receive regular updates.
Autodesk Fusion
Join Fusion Insider
Message 7 of 9
patmat2350
OK thx, this turned into a mess with failed installs.
I'll take it to the support forum as directed here:
Message 8 of 9
RajkumarIlanchelian
@patmat2350 Please do attach the logs here. I can take a look.
A restart of the machine and then a repair could help too.
Autodesk Fusion
Join Fusion Insider
Message 9 of 9
patmat2350
Thx, already resolved in the Support forum, required a tedious manual uninstall
