Static stress simulation using mesh body from topology optimisation in Fusion 360
SAIAAKASH2002
SAIAAKASH2002
Is there a way to direct perform static stress simulation on topology optimisation output without post-processing??
shekar_sub
Hi  SAIAAKASH2002,
You are asking if there is a way to do a Solve on the topology optimization output.  The output of a topology optimization output is a mesh and we have no way to send that mesh to another solve directly. You will have to process the output manually by either creating new geometry using the mesh as a guide. Converting that mesh to a solid and then sending it to LSS solve is not recommended. Thanks
Best regards
shekar
