I was trying to do a statical stress simulation. The mesh & variables solved fine since I can see their values in the error page, but then it gave this error:
CH-SPACEFRAME-04a-P v15: Simulation Model 1 - Study 1 - Static Stress
_____ 2021-01-21 17:13:22 _____
_____ 2021-01-21 17:13:25 _____
134766 T : 100.0% of elements (100.0% of volume)
Face Angle min: 0.0582, max : 178
Dihedral Angle min: 0.0193, max : 180
Worst shape ratio : 7.87e+03 on element 22
Worst aspect ratio : 999 on element 1219, shortest edge: 4.49e-06, longest : 0.11
Lowest collapse ratio : 0.000335 on element 22
Worst Jacobian ratio : 1 on element 1
Base mesh: 253606 nodes, 134766 elements
Solver mesh: 253606 nodes, 134766 elements
Job has finished with errors. Receiving results.
Error: NON-ZERO OR NON-BLANK DATA REQUIRED IN FIELD 2
Cause : The specified Bulk Data entry field required a nonzero (nonblank) value.
Action : Add the correct data to the specified field.
Error: ID OUT OF ALLOWABLE RANGE (0-99999999) IN FIELD 2
Cause : The specified Bulk Data entry or Case Control command referenced an identification number
that is out of the displayed allowable range (0-N).
Action : Change the number to within the displayed range.
Error: ID OUT OF ALLOWABLE RANGE (1-99999999) IN FIELD 3
Error: Solver Error
Error: An error occurred while solving the model.
I solved it locally and I tried with manual materials and the ones in Fusion library. The file is attached.
Thanks for helping
Simeng
Hi Simeng,
The problem is you have more than 1 point mass attached to the same geometry. That does not work.
Even it it would work, the point masses are connected to the geometry using rigid connectors. Because a large percentage of the frame has a rigid connector, there is almost nothing left that is flexible!
Here are my suggestions:
