Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
FEA Results threshold editing
1 REPLY 1
sebastiano.vergara8ZQ9J
241 Views, 1 Reply
Hello everyone,
Just wondering if anyone knows if Fusion360 Simulation colour code thresholds can be modified or only the fading away through the double arrows are possible?
Suppose the maximum & min Von Mises stress of simulation results is in the range 0-200 MPa, is there a way to set the blue colour to let's say to 30 Mpa and red to 60 MPa?
I aim to better display the global stress levels and cut off the very high point load stresses.
Thank you in advance
Sebastiano
Labels (5)
1 REPLY 1
Hi @sebastiano.vergara8ZQ9J
Try "Results Tools > Legend Min/Max" and "Results Tools > Legend Options".
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Technology Administrators
