FEA Results threshold editing
sebastiano.vergara8ZQ9J
Hello everyone,
Just wondering if anyone knows if Fusion360 Simulation colour code thresholds can be modified or only the fading away through the double arrows are possible?
Suppose the maximum & min Von Mises stress of simulation results is in the range 0-200 MPa, is there a way to set the blue colour to let's say to 30 Mpa and red to 60 MPa?
I aim to better display the global stress levels and cut off the very high point load stresses.
Thank you in advance
Sebastiano
John_Holtz
Autodesk Support
Autodesk Support
Hi @sebastiano.vergara8ZQ9J
Try "Results Tools > Legend Min/Max" and "Results Tools > Legend Options".
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
