Square to Cube
Square to Cube
Message 1 of 11
Square to Cube
I have a square with a weird side length. It isn't directly given a dimension, the side length is based on a few constraints. How do I make a perfect cube with the weird side length? Ideally, what I'd want is some way to constrain the side length and the height to be the same, so it's a perfect cube, but I can't figure out how to do that.
Replies (10)
Message 2 of 11
laughingcreek
attaching your .f3d model, or at lest some pics would help people understand your question.
Message 3 of 11
JHRendon
It is better to use the rectangle figure to make a square. When you clic on the rectanlge, this gives you 3 options to make the figure. If you make the square with lines, check you add "Horizontal/vertical" constraint, and the "equal" constraint, so all the sides should have the same dimension. 🙂
Message 4 of 11
I found the measure option when extruding my square, and I've used that to make the height of the cube the same as the width and length.
Message 5 of 11
JHRendon
Oohh ok, So the problem was the height. Good to know you solved.
Message 6 of 11
This is what I did
Message 7 of 11
laughingcreek
is it parametric?  when you change the size of the base of the square, does the height change automatically, or do you have to go back and change the extrude?
Message 8 of 11
I found out it is unfortunately not parametric, so I'll have to keep looking for a better solution
Message 9 of 11
JHRendon
You should add a parameter with the dimension you want
so when you make the sketch add the parameter to the dimension
the same when you extrude it
so when you want to change the cube size only change the parameter dimension.
Message 10 of 11
laughingcreek
take a look at the attached. double click the dimension and change the value.
Message 11 of 11
This works perfectly, Thanks!
