Trying to Print a Cutting Template to Scale (Larger than 1 Sheet)
Hey there,
I'm trying to do something very simple but none of the guides I've found online have worked so far.
The objective is to take a Sketch (or body) from my project, in this case an 18" long DXF outline of Maine that I imported, and print it on (2) 8.5"x11" sheets of paper (because the total sketch is larger than my home copy paper).
The plan is to attach the sheets of paper together and then use them as a cutting template on a wood panel board I glued up.
What's the best way to get there using fusion? I have been messing around in the drawing workspace with the 1:1 scale option, but F360 isn't generating a second worksheet to continue the sketch onto, and it seems the PDF export is disabled for the free version anyways.
g-andresen
try this:
1. FILE > print > select „Print to PDF“  instead of your hardware printer
2. Select multisheet output
günther
