- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I have been working on a very simple (or so I thought) model for a joint (which is essentially a box), that will join up with some rods, see picture. I've applied a fillet on the edges that need a smooth edge, however there are two planes which require a flat surface but with radius corners which should taper smoothly into the vertical edge. I am referring here to the corners I marked in red. I used the sketch view to position two arcs with the appropriate radius on the edges thinking I could just remove the surplus above or pull the square plane into a curve, but I just can't work out how to solve this sadly.
I gather it is probably something really obvious, like a tool I may not have used before or a different workflow. Any tips?
Really stuck with this, any help would be great!
