- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Simple explanation for a complex problem.
I use the sheet metal tool to make a "Hairpin" conductor similar to those found in axial flux brushless motors.
Now I want to split that body into dozens of layers so I can get the correct dimensions for foil punches.
If I punch the foils all the same as I bend them the farthest out foil in the hairpin covers more distance due to being outside the bend and the inner foils cover less.
Is there a way to cut these conviently or do I have to make each individual foil its own sheetmetal component and draw the dozens of layers by hand?
Its difficult because its so complex with lots of bends in different directions.
Without attaching the drawing (I am not allowed) the best description is an lampshade wire that is twisted so one leg is bent forward and one backwards so they no longer lie in the same plane.
Is there a way if I have to do it manually to join sheetmetal shapes together via the join command?
Thanks JC
