How to connect bodies in different planes
girard.ibanez
Message 1 of 10
girard.ibanez
I am trying to make a bracket from one body to another. I have a upper rectangular plate 102mm x 150mm that sits 75mm above a tubing that is 8mm in diameter and 15mm long. The tubing is 65mm off to the rectangular plate side. Both bodies start at the same distance.
I want to connect the tubing to the front of the rectangular plate to form a bracket. The bracket will be 15mm wide extending to the front of the rectangular plate.
Replies (9)
Message 2 of 10
TheCADWhisperer
Message 3 of 10
girard.ibanez
Heres the f3d file
Message 4 of 10
jhackney1972
There are many ways to do this, mine may not be the best or the worst but it seems to satisfy you request.  You may want to add a web gusset inside the bend for strength.  Model is attached.
John Hackney, Retired
Message 5 of 10
girard.ibanez
Hey Thanks but it needs to connect to the front at a diagonal. The dotted lines when viewed from the LEFT. Also see the screenshot of the actual picture.
I believe to do it requires the LOFT function, but not sure.
Message 6 of 10
jhackney1972
You request was not clear on the diagonal line.  Also there are two diagonal lines, I chose the inside one.  Model attached.
Message 7 of 10
girard.ibanez
The ruler is the brace
Message 8 of 10
KristianLaholm
Here is a possible workflow using Plane at Angle.
Added a line in Sketch2 for the plane and removed some duplication and unused sketch.
Message 9 of 10
girard.ibanez
Thanks thats it.
Message 10 of 10
loudonbendall
My initial thought is to create a loft between the two bodies and then shell the loft. Lofted file attached below.
