I have a SVG I imported that contains 4 objects. All separate
I want to split it into 3 separate components so I can send to my 3D Printer and print in different colors.
It's a basic circle base with the image on top that I want to extrude out a couple mm. I need the Beak parts in one component, the eye in another, and the feather in another component.
Attached is the file.
Extrude each in turn as a separate component. I use an Extrusion of 1mm which you can change as desired. Model attached.
John Hackney, Retired
