Split Ducting
Split Ducting
Spielmanmj
Split Ducting
Spielmanmj
HI,
I'm trying to create a 6 inch duct that splits into two 4 inch ducts for a smoke extraction system for my laser cutter. Do I use the Loft Tool? It says it can loft more than two profiles to another but I can't figure out how to do it. I'd like to do something like shown in the attached picture. Also attached is the Fusion file with the easy part done.
Michael
Warmingup1953
In its simplest form...... Loft and the loft again gets you there....Check New Body then combine and shellCapture.PNG
g-andresen
another way
günther
Spielmanmj
Wow, thanks! Really nice work and I definitely learned something. On another note, what kind of mouse are you using? I notice when you orbit the pointer doesn't move. Looking to upgrade mine.
Spielmanmj
Thanks, this works well too and a lot simpler. I'll probably use this for now until I get a little better with Fusion.
g-andresen
3D Connexion Space Mouse
günther
