Issue with Sketch.
Issue with Sketch.
andrew_bryan1
Issue with Sketch.
andrew_bryan1
Community Visitor
Community Visitor
I am new to Fusion and I learn by doing. I am having a problem with this sketch and I have a hunch it has something to do with constraints. I have been at it for hours and even made a new sketch and it has the same issue. I have been using Chat GPT to guide me and it was all working great up until now. Please help!
andrew_bryan1
Community Visitor
Community Visitor
Here are the files if needed
davebYYPCU
I presume you need the “profile”.
In the edit sketch pallet, tick to turn on Show Profile.
or, while in edit sketch, window select all articles, right click, and Select, Move to Sketch Plane.
Might help….
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned
to the forum for further guidance.
If ChatGPT was actually any good at teaching instead of regurgitating you might have learned something. Time spent
reading the documentation and doing the embedded tutorials is NEVER wasted.
Cheers
Andrew
jhackney1972
You have a 3D Sketch so I created a Surface body from it.  You can use the Thicken command to make it into a solid body but I do not know what you want to do with it after that.  I have attached the file with the surface so you can play with it from here.
John Hackney, Retired
