Split Body Workflow?
cooperAL5P5
cooperAL5P5
I can't figure out how to separate the switch from the encasement in this .STEP file, into two separate bodies. I tried starting with a Split Body using the inside long flat side faces adjacent to the switch, but I just get intersection errors. Would anyone be able to explain the process for something like this?
Thanks!
davebYYPCU
All works Ok my end.
I used Extend cutting tool,
Then found there was some draft inside the slot, so deleted those faces.
Red plate is not part of the switch anymore.
Might help....
TheCADWhisperer
Examine the Attached file.
cooperAL5P5
Ahh ok, so @davebYYPCU
TheCADWhisperer
Unstitch the surfaces.
Segregate the two components (or bodies) into Groups.
Repair the Pins.
Repair the Holes.
Stitch back to solids.
