- Mute
- Permalink
- Report
I searched with Google and I've searched this group, but can't find out why after doing a "Split Body", the majority of the time I can't find the "Remove" command. Only the "Delete" which when I use it usually, but not always removes both of the split bodies. And often, after that occurs and I use the ctl-Z to undo it, the "Remove" command becomes visible and functions the way I anticipate. Other times, if it is not, the "Delete" may perform like a "Remove"! This is VERY frustrating!
Using 2.0.9719, Personal, on Windows 10.
