Announcements
How to Align 2 gears together in Fusion 360 from GF Gear Generator.
jakeq21
jakeq21
Hi all,
I've just downloaded and installed the GF Gear Generator in Fusion 360 which is great.
What I want to ask is, if I create 2 gears with central holes and I want to design a platform for them to sit on and mesh together so that they rotate together, is there a specific rule or method of creating the distance of the axis that the 2 gears sit on so that they mesh correctly.
Sorry if it sounds like a silly question, I thought the gear generator would create something like a construction circle around each gear that you would line up, which I think I have seen in a video I watched about creating spur Gears. I haven't designed anything specific yet, but I am planning on designing several projects with 3d printed gears and would just like to know the right way of doing this, so that the gears don't mesh too loose or grind together too hard when 3D printed and assembled.
Many thanks
Jake
Replies (9)
HughesTooling
Fusion has a script that generates gears and creates a pitch circle as part of the gear component. You load the script from the tools tab. If you're creating gears using module the pitch circle is pretty easy to calculate, just multiply the number of teeth by the module. So a gear with 20 teeth and 2.5 module will have a pitch diameter of 50.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Just experimenting with the Fusion script and it looks like if you want to use diametrical pitch(DP) you just divide the number of teeth by the DP. So a DP of 10 with 30 teeth gives a pitch diameter of 3.0.
Mark
Mark Hughes
TheCADWhisperer
@jakeq21 wrote:
I thought the gear generator would create something like a construction circle around each gear that you would line up...
I create surface body cylinders of the Pitch Diameters for this purpose.
The surface bodies can then be hidden.
jakeq21
Hi Mark,
Thank you for your reply. I just tried creating 2 similar gears in the 'Spur gear' script in Fusion.
So to make a base with 2 spindles for 2 identical gears to sit on and rotate, would I sketch 2 circles next to each other making both their diameter the same as the pitch diameter of my gears, set a tangent constraint for the 2 circles so they touch together and then use the center of both these circles as the spindle center for both the gears to sit on, does that make sense?
Many thanks
Jake
jakeq21
Hi TheCADWhisperer,
Yes I can see 2 construction circles when I create a gear using the 'Spur Gear' script in Fusion, although I am using 'GF Gear Generator' which I got from the Autodesk Fusion App store as it can create  double helical gears and I have been playing around creating some of these, but I am not able to see a Construction circle around the gear when it is created? I can always draw/sketch a construction circle around each gear I suppose. Maybe this App just doesn't generate them.
Many thanks
Jake
jakeq21
Hi Mark,
Sorry, I think I may have been over thinking this, surely I would just divide the pitch diameter by 2 to get the radius and do the same for the other gear I want to connect/mesh to and add these amounts together, and that will give me the distance I need between the 2 spindles.
For what I'm doing fine accuracy is not so important, so I think that will work. I'm not an engineer so not really worked much with gears.
Jake
HughesTooling
@jakeq21 wrote:
Hi Mark,
Jake
Yes that's all I do. If you are using module, just add the teeth on both gears multiply by the module then divide by 2 and may be add a bit for clearance. You can do this in a parameter to make it easier to keep a track of.
Something like this.
Mark
Mark Hughes
jakeq21
Thanks Mark,
Yes that sounds like a good idea using a Parameter, thanks for all your help!
Jake
garinSK4EU
Love the details, thanks for sharing.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
