spline tool type
spline tool type
spline tool type
Just curious to know what type of spline f360 is using for the spline tool? is it a cubic bezier curve? a f-spline curve? catmul spline? or something else?
thanks
TrippyLighting
NURBS
Here's a good introduction on how to work with NURBS surfaces.
In Fusion 360 there are two spline types. The fit point splines are 5-degree multi-span splines.
Then there are control point splines. See the Autodesk Alias Theory Bulders on that (2nd link above)
so it is a b-spline type. Whats the difference between non-uniform b spline and uniform b spline?
thanks
TrippyLighting
Described here in the properties section.
Edit: Just to be clear, I don't claim to understand all the blinding math behind it 😉
its all good, i can understand the maths a wee bit. Thanks for helping me out. I use another cad program as well, and i was just comparing the splines between all the different software out there. Looks like different types of splines have different places of where they put the control points. IE, on a uniform b-spline, the CV's are off of the curve, while with cubic beizer curve, the cv's are on the curve.
thanks
