Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Spline handles appear to be under the spline itself
7 REPLIES 7
Message 1 of 8
lukepighetti
364 Views, 7 Replies
Spline handles appear to be under the spline, making it a pain to click on the handles when you're trying to do an edit.
https://screencast.autodesk.com/main/details/e066ba45-489b-4f2d-8301-2c9d078086e1
7 REPLIES 7
Message 2 of 8
taylor.stein
in reply to: lukepighetti
Hey Luke,
I agree - spline handles can be difficult to select at times. One way I tend to work around this is to change my selection filter to only "Sketch Points." With this selection filter checked, you can click on spline points, and easily drag around the ends of the spline handle without accidentally moving the sketch curves.
Perhaps this is we can add to the idea station?
Let me know if this helps,
Taylor
Taylor Stein
Fusion 360 Evangelist
Message 3 of 8
lukepighetti
in reply to: taylor.stein
Hey Taylor, good idea. Perhaps it is ideastation worthy. Do you guys add these ideas internally even if they dont end up in IdeaStation? Thanks!
Message 4 of 8
taylor.stein
We do, but it's always helpful to have a reminder on the IdeaStation that the request initiated from a Fusion 360 user!
Taylor
Taylor Stein
Message 5 of 8
lukepighetti
Another example of why this is frustrating (and doesn't make sense!)
https://screencast.autodesk.com/Main/Details/4897e238-5f47-44d6-ad76-b64023f7c88f
Message 6 of 8
taylor.stein
Hey Luke,
I understand how this can be frustration, especially when working in a small area with a lot of geometry. What would be the ideal behavior that you'd like to see? For example, would you like to hold a key down to limit your selection capabilities to handles?
Happy to help,
Taylor
Taylor Stein
Message 7 of 8
lukepighetti
Put the spline handles on top!
Message 8 of 8
taylor.stein
Thanks, Luke - I'll make sure to share your feedback with our UX team!
Taylor Stein
Taylor Stein
