I'm trying to replace a decorative plate, to hide a hole.
I put a photo of the plate, scaled to the right size, on the sketch XZ plane, and proceded to trace the irregular curvy complicated outline.
Because I can't figure out how to make sharp corners between splines, I ended up using close spacing of spline points to work my way around the sharper corners, so there's an unreasonable number of points defining the spline outline.
However, I can select the interior and extrude it to form an acceptable starting base for the part, even excluding two holes for the screws.
Then I want to fillet the edge. Can't be done. The holes (defined by circles) fillet just fine, but no matter the fillet radius or other settings I always get an error message that the fillet can't be generated.
I'm surprised that the outline can be selected and the surface inside it pulled up, with no problem (OK, at first I had a stray piece of line doubled that had to be found and removed, but after that it worked), yet there's no fillet possible. I tried making a simple closed curve with splines, and that extruded and also filleted without problem.
So the trouble has to be the complexity of my traced spline.
There ought to be instructions somewhere for how to draw with splines, including how to create corner points and what the checkmarks mean, but I can't seem to find it for Fusion 360.
I'd upload my file, but I guess it's in the Cloud--not a file on my computer. Is there a way to upload it to show my problem? Export shows an Archive format, would that be the one to use?
A Noob
