Spline around 3d box
cornell1980
Message 1 of 10
cornell1980
I have a simple box and would like to draw a continuous spline around all four surfaces.  I can create a spline on one surface (sketch), let's say the left, then turn and create another spline on the front sketch and start and stop them at the same place on the corner and it kind of looks like they are a continuous spline but they aren't really.  I've attached my file so maybe looking at it will make more sense.  Ultimately I want to create a small pipe around the box for decorative purposes.  Can anyone help?
Tim
Replies (9)
Message 2 of 10
jhackney1972
Since a Spline has a natural curvature, it is very hard to keep in exactly on the surface of a sharp cornered box.  Attached in your model with a continuous spline around it but as I say, it dips in and away from the exact surface.
John Hackney, Retired
Message 3 of 10
cornell1980
Let me change the example.  Let's say instead of a box it is a cup.  How do I draw a continuous spline all the way around the cup?
Tim
Message 4 of 10
HughesTooling
Is the cup a continuous surface? If it is create a plane where you want the curves then a sketch on the plane and use project intersect Shift+P.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 10
Warmingup1953
That might be easier! What are you trying to achieve?
Message 6 of 10
davebYYPCU
Easy enough, but not with sketching.  Box is the same.
Might help....
Message 7 of 10
g-andresen
what you need is a small fillet between the faces.
Try this
(view in My Videos)
günther
Message 8 of 10
cornell1980
I'm trying to make a cup/lattern that has decorative lines going around
it. I tried unfolding the cup, drawing the splines, then refolding the
faces, and that kind of works...
[image: image.png]
But as you can see when the refold occurs the splines don't meet up or
appear smooth.
[image: image.png]
Any advice would be appreciated.
Tim
Message 9 of 10
Warmingup1953
No images inserted or attached
Message 10 of 10
TrippyLighting
As I am sure you've discovered by the replies so far, sketching directly on a curved surface is not possible in Fusion 360.
This is fairly advanced functionality called COS or curve-on-surface and I don't expect for this to be implemented any time in the foreseeable future.
The sheet metal method of "wrapping" a curve around a developable surface, however should get you there. It might simply be a case of applying the technique correctly.
Once you manage to properly attach a .f3d model to a post I am sure we can demonstrate how to do this.
