Spirograph-3d print model
dalepack
Message 1 of 8
dalepack
Hi everyone.
I am trying to recreate a 3d print of a sculpture I like. I do not know if it is possible with 360 so I hope you can all point me in the right direction as I am a novice at this. Thank you.Spirograph SculptureSpirograph Sculpture
Replies (7)
Message 2 of 8
etfrench
That shouldn't be too hard.  Here's one crude way to demonstrate the technique.  It's basically a circular pattern of a helix.  I used a coil with a triangular section.  It would be better to use the coil as the sweep path for a custom profile.
Changing the axis position of the circular pattern and the revolutions of the helix can create an infinite number of models.
ETFrench
Message 3 of 8
TrippyLighting
This does not look helical to me.
@dalepack would you have other images of this object ?
Here's my WIP so far in T-splines:
Message 4 of 8
davebYYPCU
I would also need another view of the object but from 2d I went for Patch Loft to find the shape, and obviously the depth is off.
Might help...
Message 5 of 8
etfrench
Here's one with a different axis and some of the clones suppressed:
ETFrench
Message 6 of 8
etfrench
These are rather fun:
ETFrench
Message 7 of 8
dalepack
Thanks for the effort. If you type "spirograph sculpture next" into google you will get a few images.
Message 8 of 8
TrippyLighting
Thanks. That confirms that I am on the right track with my approach 😉
