Spiral Motion
Spiral Motion
ManikantaAthukuri
Spiral Motion
ManikantaAthukuri
Hello
I have started modelling a 3-jaw chuck. The motion between the jaw and the spiral plate is a spiral motion.
How can we achieve the spiral motion in Fusion-360. For now, I have made a motion link between the spiral plate and jaw.
If you know the solution please do share. It will be helpful.
I am attaching the .f3z file for reference
Manikanta Athukuri
Accepted solutions (4)
davebYYPCU
It appears to be working, other than the rest position, or closed distance adjustment.
I have not studied the model, as what I was going to say has been done.
Might help....
ManikantaAthukuri
Thanks for the reply. Yes, I have finished motion by making a motion link between the joints. But it is not accurate. The rotating motion and the sliding motion are not in sync.
Manikanta Athukuri
davebYYPCU
Well I got to the motion link, you have 15mm slide for one revolve, you should use the pitch of the spiral thread, if it is not 15mm.  The tooth spacing is 6+ mm, but as stated not checked - if it is a single or triple start spiral coil, or whether the chuck key is / would be functional.
Might help....
ManikantaAthukuri
Ok, thanks for the update. I will try to adjust the measurements as you stated
Manikanta Athukuri
davebYYPCU
How did you go?
I am closer to "ëxpected"
Pitch of the single start spiral is 6mm.
I edited the Motion Links to 360 deg = 6mm.
(not sure of your formula in this area, but one turn disc is 6mm in the jaw.)
I also gave more jaw travel (-45 to 15) in 2 of them and changed the other one to -12 (so 18mm inwards on all).
and found this .... that you may know how to re-align the 2 that are too wide. (1 tooth out -> in)
(PS Been there done that in real life)
Might help....
ManikantaAthukuri
Yes by adjusting the rest positions We can get almost "expected" motion. I tried it in the motion study. So It is closer to the needed motion. Thanks for helping.
Manikanta Athukuri
