- Mute
- Permalink
- Report
So I must be using Autocad Fusion360 wrong because it really does not want to let me cut this sketch in either direction from the middle of this object. I have tried making the sketch on both a midplane and an offset plane. Cutting from the outside in seems to work fine but Fusion seems to refuse to keep the interior sketch selected when I hit extrude? (second picture)
(below showing sketch selected)
below showing immediately after hitting extrude, notice sketch no longer selected and no extrude arrow present
So..I just have no idea why I can't cut from a sketch from the inside of the object...I even tried another offset plane from another dimension and a different offset so it isn't in the middle of the object, still no dice.
Why on Earth am I having problems doing something as simple as trying to cut a sketch from inside a solid object?
