Solidworks Import Limitations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am really hoping to be able to import several of my current designs from Solidworks into Fusion, and use Fusion exclusively going forward. But, so far, this appears to be both laborious, and of limited functionality. I'm hoping there is something I'm missing.
When I import a Solidworks part file, I end up with a lovely-looking Fusion model. Some features, however, are not editable, or only partially editable. For example, for a simple part that is basically a 3/16" flat plate cut to a complex shape, with a number of thru holes, and a single pocket, I can edit the thru holes in simple ways, but I cannot modify the overall shape of the part, nor can I modify the pocket in any way. When I edit the holes, if I use references to specify the location of the holes, those references seem to get thrown out, as soon as I click OK. When I re-edit the holes, it shows NO references.
Am I missing something?
The file in question is attached.
Ray L.
