SolidEdge import problem?
post
1,876件の閲覧回数
10件の返信
メッセージ1/11
post
I am using Solid Edge in Parralell on Mac. Unable to import files from Solid Edge to Fusion 360. Is it because I am importing from a Windows application to Mac program?
Can anyone help.
Tore R.
0 件のいいね
1,877件の閲覧回数
10件の返信
返信 (10)
メッセージ2/11
schneik-adsk
Export from SolidEdge as x_t or x_b parasolids file.
Fusion 360 does not have a native SolidEdge translator today.
Kevin Schneider
0 件のいいね
メッセージ3/11
post
Tried to export from Solid Edge with x_t or x_b paralsolids, this is not working.
Will there be a translator for Solid Edge, and if so, when?
Tore R.
0 件のいいね
メッセージ4/11
ADSKDJW4
Hello Tore,
I am not sure if this has been entered as an enhancement request as of yet but below is the link to post this to be added.
Fusion Ideas Station
Once posted you can look on the Fusion RoadMap to see when new enhancement will be implemented.
Best Regards,
Don Warner
0 件のいいね
メッセージ5/11
schneik-adsk
Can you be more specific on what is not working? Is the export not working or the import?
I apologize for the trouble. I import parasolids data myself and can confirm the import works. So there might be something special about the SolidEdge data? IS is unusually large/complicated? Surfaces, sketches or mesh data?
Kevin Schneider
0 件のいいね
メッセージ6/11
post
Hi post,
It is importing from Solid Edge that does not work. I use a Mac with Fusion 360 Mac verson and Parallel with Solid Edge. Could it be that I try to import from Windows to Mac?
Tore Røgeberg
Can anyone help.
Tore R.
0 件のいいね
メッセージ7/11
post
Hi Kevin,
Tore Røgeberg, Oslo, Norway
0 件のいいね
メッセージ8/11
適用対象外
Do you mean that no imports from Solid Edge are working? Or just one particular set of files?
If its just one set, try importing them into solid edge as parasolids and see if they even come back into the native software cleanly.  Solid edge has always been pretty good to me about making translatable geometry, but sometimes things imported into it from other software can cause problems for downstream users with other software.  SE is tolerant, so you dont notice until you hand it off.
Interested in how your getting along overall, as I intend to use F360 for early concepts projects and SE for more sophisticated projects where the part counts are high.
Eric Peterson
0 件のいいね
メッセージ9/11
RogerMollon
Tore,
Fusion 360 doesn't read native SolidEdge files (extensions .par, .asm, and .psm), whether it's Windows or Mac doesn't matter.  Fusion 360 does read the Parasolid Files (extensions .x_t and .x_b) are portable so, if you write them out of SolidEdge, again Windows or Mac doesn't matter.
I hope this helps,
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
0 件のいいね
メッセージ10/11
post
Yes, it slowed the problem. If I sawed in SolidEdge as Save as translated and then as Parasolid (x-p,x-t) it woks perfect.
The only problem it that the part is on the wrong origin. The top of the part is on the side origin. Can I turn the part so that the top is on the top origin?
Tore Røgeberg
0 件のいいね
メッセージ11/11
schneik-adsk
Use the view cube in the upper right to loo at the model how you wnat front or top to look.
Right mouse click on the view cube and set the current view to front or top.
This will reset the view as you wish.
Kevin Schneider
0 件のいいね
