Snapping in section Analysis.
pheron_301
pheron_301
Can anyone shed some light on how to snap or create a drawing in section analysis.  My goal is to double check that the pitch is what I intended.  Thanks,
Philip
HughesTooling
You need to create a plane at the same position as your section, create a sketch on the plane then use project intersect. Also in sketch mode you have Slice so you don't need to create a section first.
Mark Hughes
Owner, Hughes Tooling
