I'm facing a very strange situation I could not find any solution at this moment.
I have created few components, some are assembled on a PCB.
Now time is to create a case for my project.
I have done two assembly trials, and wanted to create a case for the second version.
Here is how the assembly looks like :
I'm creating a new project, then I pick up from my project the one above
=> you can see at the bottom the cylinder.
After I drag an drop to me new project, I'm actually getting the wrong assembly 😳. See below
=> you can check the component name is the same as the one I've just shown above, the the way the pieces are assembled is incorrect !
How can this be and how could I fix this ?
thanks for your help, I'm currently stuck in my project.
thanks!
Michel.
