Snap
Snap
Message 1 of 12
Snap
Hi
Simple task but not for me. Just trying to copy this black solid and want to
place it on the middle of the blue marked edges. Why does it not give me any points
on the either of the two solid edges. Corners yes but not midpoints anywhere.
Matias...
Replies (11)
Message 2 of 12
SaeedHamza
Use the "point to point" move tool, it should work
Regards
Saeed
Saeed Hamza
Message 3 of 12
Not when I want to move it only sideways along that axis.
I think this is a basic command and nothing unique so why dont it show snappoints also in the middle?
Message 4 of 12
SaeedHamza
watch this please
I hope it helps
and if I misunderstand, please provide a screencast to explain
Regards
Saeed
Saeed Hamza
Message 5 of 12
Thanks.
Ofcourse I get it moved to where I want if I go another way. The question
is why it does NOT snap to midpoints as it does to endpoints? As seen here
if I'd want to move the other solid I can easily place the marker on the very same
middle edge point I just tried snapping too, funny...
Matias...
Message 6 of 12
SaeedHamza
Strange, because it snaps just fine with me
watch this :
Saeed Hamza
Message 7 of 12
Seperate bodies, yes. Point to point snaps fine but then you also shift sideways
and I dont want that, only along one axis. Thats why I use free move and select only
the arrow which I want to move along but then i cant snap to any other points than the ends.
Same for you or is it just me?
Message 8 of 12
SaeedHamza
Oh now I see... it's true, you can't snap like that using the free move tool
now that I understand, your only option is to align the body to the middle, and for that you need a plane or a face to align to, and that leads us back to my previous screencast when I made a plan at angle and aligned the body to it
Saeed
Saeed Hamza
Message 9 of 12
But why not? because when position the free move tool it sure finds all the snappoints. This is something that needs to be fixed, that way it would be much easier and smoother.
Message 10 of 12
PhilProcarioJr
@Anonymous
I agree you should be able to do this with the move tool. Add it to the idea station and I will vote for it.
There is a way to do this with a joint and the move tool but it should be a lot simpler then it is.
If they would add the ability to constrain along an edge or axis in the move tool then point to point would work fine.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 11 of 12
PhilProcarioJr
@Anonymous
I know this is not the way you want to do it but it is a work around...
Phil Procario Jr.
Message 12 of 12
Hi Phil
There are alot of workarounds, I know  🙂
Not that I dont get the job done but things you've picked up from other programs
and found useful. This aint some miracle function so I dont see why not use it.
Go on and vote then  Smiley Wink
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/object-snap-with-free-move/idi-p/713...
