Smoothing BREP created from STL
Hi all,
I'm trying to modify an existing part but as it is generated from an STL it's a collection of flat faces even as a BREP. I'd like to make it smooth. For context of the screen grab, it is a hollow cylinder with an internal thread designed to fit over a vacuum cleaner hose.
Many thanks.
davebYYPCU
Make your brep body with Fusion tools, using the stl for reference.
Might help....
How would I accurately model a triangular profile helix please?
davebYYPCU
Triangle coil or sweep.
Thank you 🙂
TheCADWhisperer
Attach your stl file and can you File>Export your *.f3d attempt to your local drive and then Attach it here to a Reply if you can't figure it out.
That's really kind, thanks. I'll have a copy this evening at doing it myself
first and then come back if I fail.
Cheers.
