Smooth out corners? (was compute error on slice)
JamieMacL
JamieMacL
I'm trying to slice a body with two splines that are mirrored across an axis.  The first split succeeds, but when I try to slice with the mirrored spline I get a "failed to compute" error with no additional information
I fixed the compute error by extending the slice.
Now my issue is how to make the transition between the body parts smooth - see circled area
I want to get the slice to slice along the contour of the extruded part.
Thx
jhackney1972
Just one idea.  Model attached.
John Hackney, Retired
JamieMacL
I thought of using fillets like that, but what I'm looking for is more like there being one line on the bottom of the contour like this
TrippyLighting
I would start this from scratch!
If this is supposed to be a symmetric design, then it should center about the origin, for example.
JamieMacL
Happy to do that, but I still don't know how to make that contour.....
TrippyLighting
Is this what you are looking for ?
JamieMacL
That's exactly what I'm looking for!  I have to say I don't understand a couple things
In Sketch 2 you have a purple (?) line across the top of the body - what purpose does that serve?
Step 12 - totally threw me off with the Plane2 step and following sketches.  I don't understand how those work.  Looks like magic 😎
Thanks!
