Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Small project icon in the data panel
2 REPLIES 2
703 Views, 2 Replies
When you look at all the projects in the data panel, there is a small triangle with 3 dots on the left of available projects. I noticed that some demo projects as well as samples have a small rendered graphic in place of the triangle.
Is there a way to place a render image in the project panel?
2 REPLIES 2
That triangle denotes a folder which might have so many files inside it. But you save a single .f3d directly on the data panel that project will be shown with a rendered image as its icon. Till now there is no way to to put rendered image as a icon for the project
x3msnake
Well you can change the icon by clicking on your name on fusion
then on the web browser on your hub, open the project folder and hover the icon and click edit, you can upload your own icon by clicking on the wite box of the popup
