STP file conversion
STP file conversion
Message 1 of 13
STP file conversion
Hello All,
I'm a complete noob to Fusion and have run into a problem that I'm hoping someone might help me solve.
I understand that this may not have a solution or my skill may keep me from accomplishing what I wish, but here it is.
I got an STP file from a company for an accessory that I would like to modify for my personal use.
I didn't have a problem importing and opening the file.  The issue is that I can't alter the piece.
I am trying to delete portions of the object so that I can add a modified area, but I can't seem to get it to work.
I am aware that I am probably doing something wrong, but I just want to make sure that it is me and not the file.
If anyone has any suggestions, I would really appreciate the assistance.
Thank you.
Replies (12)
Message 2 of 13
buymeanapple
I am not a super advanced user but I have run into the exact same issue and was able to figure out that there really isn't a way to edit an STL file in Fusion. The best way to edit the STL would be to use a tool like meshmixer (http://www.meshmixer.com/). You can import it there and do simple things like removing sections or editing them slightly. Editing an STL is a pain in the butt. If someone else here knows of a better way I would love to hear.
Hope this helps!
Message 3 of 13
JDMather
@buymeanapple wrote:
.... there really isn't a way to edit an STL file in Fusion.
stl and stp are two very different file types.
Message 4 of 13
JDMather
@Anonymous wrote:
I got an STP file ...
If anyone has any suggestions, ....
Can you zip and attach  your *.stp file here?
Message 5 of 13
I've attached the file.
I am trying to alter the center section that contains the script.
I need to expand the section to accommodate some electronics.
Let me know what you think.
Message 6 of 13
TheCADWhisperer
How much CAD training/experience do you have?
Editing this file is not a beginner level endeavor.
Are you familiar with Split body and Move Body? Combine?
Looking at the part from text right reading -
do you need to expand left to right
or from top to bottom?
How much do you need to expand?
Are you familiar with direct editing tools?
Can you request that the source edit the file?
Can you attach the original Pro/E file?
Message 7 of 13
I have very little training and experience.  I presented the issue only to confirm that what I would like to accomplish is possible.
If it is possible, I will, hopefully with some tips from the forum, learn how to make the changes.
I am looking to "pull" the middle section out from its original plane in order to create a cavity in which to mount additional electronics.
This is and will be the only file that I have is available for this project.
Message 8 of 13
cekuhnen
@Anonymous
Oh boy - well you learn through practice.
Fortunately the direct modeling in Fusion is pretty solid.
If you need help we could meet on Skype to give you some directions
and get you running.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 9 of 13
jrinad70
Go to this link and select the video "Using Direct Modeling in Fusion 360 to Take Your Models to the Next Level".  It's the 4th video down.
https://forums.autodesk.com/t5/post-your-tips-and-tutorials/autodesk-university-class-recordings-now...
Message 10 of 13
TheCADWhisperer
@Anonymous wrote:
...confirm that what I would like to accomplish is possible.
I would say possible, but very challenging for a beginner.
In the attached file I have split away an end (I didn't take the time to calculate a distance to duplicate existing design repetition).
(and I did cut through the center of two cylindrical bosses that would have to be replaced)
I would fill in the missing volume following the same geometry representation in the original (unless you need a specific dimension that would require "stretching or compressing" existing patterns.
Mirror to other side (after splitting other side.
Combine to put it all back together again.
If you don't need the text - then the entire process might be simplified a bit.
Edit: Rather than editing the original - this one might be a good example to reverse engineer and create from scratch using your required dimensions.  It would give you good practice and probably be easier than editing for a beginner.
Message 11 of 13
Thanks for your help on this.  I appreciate any and all suggestions.
Also, thanks to jrinad70 for the video link.
Message 12 of 13
Don't know if you guys are still monitoring this thread, but I want to share the result of my inquiry.
There are a few finishing touches, but the basic design that I wanted to accomplish is done.
Screen Shot 2017-04-07 at 2.39.23 PM.pngThanks again to all who helped
Message 13 of 13
JDMather
Smiley Very Happy
Well, that is not at all what I thought you were after - that should have been a very easy modification.
If you could include some sort of sketch on your image next time - it might help understand the design intent.
Raise the center section might have been a better word description.
