Slot dimensioning
Slot dimensioning
Slot dimensioning
I'm trying to put dimensions on a slot in a sketch, but I'm not able to pick the external point on diameter to dimension the maximum length... Am I doing anything wrong?
The only way I found was to put a point manually on the half-circumference at left and right and then using those for attach the dimension lines.
Thank you
Marco
HughesTooling
It looks like you used a centre to centre slot, try a Overall slot. See second example in this screencast.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
One more bit of info, you can select midpoints for dimensions directly if you hold the Ctrl key down while the mouse pointer is near the midpoint of a curve.
Mark
Mark Hughes
Hi Mark,
thanks for your kind reply, but it does not work for me. Holding down the ctrl button does not sort any result in selecting the mid point. For a line it selects the line and for a circle, it select nothing. To select the center point of a circle, I've to pick its center point precisely or a point on the circumference, but Fusion 360 does not indicate to me any midpoint.
Thank you
Regards
HughesTooling
Sorry gave you the wrong information, you need to hold the Shift key down to pick midpoints. With circles there is no quad snap so you'll need to draw a point on the circumference then add a Horizontal\Vertical constraint between the point and circle centre or draw construction lines.
Mark
Mark Hughes
Ok Mark.
Shift does the trick.
Thank you
Marco
