Sliding lid with end stops
mbarbone
Message 1 of 9
mbarbone
Curious, is it possible to create a sliding lid for a container with end stops? (I don't know the proper wording)  All the dovetail / sliding lid box creations I've seen, the lids detach from the body. I want it to stop when it reaches the front of the box, like a drawer would.
I don't have a design yet, was just thinking about that before I start.
Mike
Replies (8)
Message 2 of 9
TrippyLighting
Sounds possible to me. Once you have a design, share the file and we'll look at it.
A paper/pencil sketch is also a design 😉
Message 3 of 9
mbarbone
This is what I did, I would like the lid to stop sliding at the end so it doesn't fall / come off.
Message 4 of 9
jhackney1972
Would Joint Limits with a Rest position work for you?  You can adjust the extent the lid opens by changing the limit values.  Model attached.
Edit: Sorry, I thought you only wanted a way to stop the model slide door from falling out of the track.  I did not read it as to supplying an idea on how to do it in a real application.
John Hackney, Retired
Message 5 of 9
Warmingup1953
Will you 3D Print? Print in place?
Message 6 of 9
etfrench
Message 7 of 9
mbarbone
3D Print
Message 8 of 9
mbarbone
@etfrench
I was thinking of something like this, but then I ran into the problem of how I did it just using 3D Printed parts. This is a good idea for another project I am thinking about.
Message 9 of 9
mbarbone
@Warmingup1953
I kept focusing on the channels to stop the lid. Just never thought of the other perspective, the back of the lid having the stop.
Thank you
